Convert different data types of FC into one KMZ file
2318
02-07-2017 04:25 AM
AhmedAbdelnasser1
Hellow everyone,
I am trying to export point, line & polygon  Features in one KMZ, Is that possible?
EX: I want KMZ containing a point with a buffer around it, and there are line features inside the buffer.
What Convert tool box provide is convert each datatype layer in sperate KMZ then I can combine it using Google Earth.
Is there a way to convert all different data types of FC into one KMZ file using python or model builder?
FC_Basson
MVP Regular Contributor
Group the different feature type layers first in ArcGIS Desktop and then export the grouped layer as a LYR file.  Then run the Convert to KML tool on the LYR file.
AhmedAbdelnasser1
Thanks, FC Basson.
Do You know What is the tool to create a group layer from the toolboxes?
FC_Basson
You just select all the layers you want to group together, right click -> Group
Then you can save the grouped layer as a Layer file
JayantaPoddar
Did you try Map to KML?
Think Location
