Conversion or Transformation from Total Station Data to ArcGIS
1761
05-27-2012 01:42 PM
ImranAbbas
Dear All!
I got a file of my all city that is the survey using total station. It have the assuming coordinates from a known point. The details availabale are as under
1. Northing, Easting (Assuming from base point or benchmark)
2. Angle
3. Azimuth
I want to convert and transform this data to origional projected data in arcGIS. I want to convert the assumed coordinates to origional ones.
Is this Possible???
1) I can convert this file in points or excel formate
2) I can also convert it to AutoCad file
BruceHarold
Esri Frequent Contributor
Hello Imran
Yes, Data Interoperability will be able to do this.  If you don't know where to start please contact your distributor, and if necessary they will work with us here at Esri to help you.
regards
