connection to PostGresSQL db with Pro 3.2.2 only shows public schema
4290
9
04-30-2024 08:04 AM
Labels (3)
JasonFitzsimmons
I am trying to connect to a PostgreSQL database that has a few schemas, including public. In Pro we can only see the public schema.
Using the same credentials in PGadmin, I can see all the schemas and all the tables and views in each one.
Something else missing?
George_Thompson
Esri Notable Contributor
I wonder if there is an issue with the version of PostgreSQL you have. With Pro 3.2.x, the minimum supported version at v13.x is 12 (https://enterprise.arcgis.com/en/system-requirements/latest/windows/database-requirements-postgresql...). That could cause an issue.
I would update PostgreSQL to 13.12 (or newer) and then retest.
--- George T.
George_Thompson
What version of Pro and PostgreSQL are you using?
Does the user have "superuser" assigned?
What are the permissions of the user in question: https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/manage-postgresql/privileges-postgre...
--- George T.
JasonFitzsimmons
Pro 3.2.2
PostGreSQL 13.4
Its a read only account, we have admin too, but the use case only needs to view the data and not edit (Data Viewer role) with the same account and same credentials, I can see all the schemas
George_Thompson
--- George T.
JasonFitzsimmons
I am a little unclear about that list, I see
  • PostgreSQL 12.16 (64 bit)
    • PostGIS 3.3
as a minimum requirement?
but it's true that we haven't updated in a while.
George_Thompson
Here are the min. versions for Pro 3.2.x:
Each major version of PostgreSQL (12, 13, 14, 15, etc..) are different from each other and have minor "updates" (.x) for each major version.
Herer is the link to the latest supported versions for windows: https://www.enterprisedb.com/downloads/postgres-postgresql-downloads
Hope that helps.
--- George T.
MarceloMarques
@JasonFitzsimmons -
How to Upgrade the PostgreSQL and PostGIS version for the Enterprise Geodatabase on Windows
How to Upgrade the PostgreSQL and PostGIS version for the Enterprise Geodatabase on Linux
How to Move the PostgreSQL Enterprise Geodatabase with pg_dump and pg_restore
PostgreSQL Geodatabase Guide Books and Database Template scripts.
Mapping and Charting Solutions (MCS) Enterprise Da... - Esri Community
use the Production Mapping guidebook for PostgreSQL, the best practices can be used by any industry.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
JasonFitzsimmons
ok thanks!
JasonFitzsimmons
thanks!
JasonFitzsimmons
curiously, I only see the public schema when i connect using ArcGIS (stand alone) catalog 10.8.2 as well.
