Connection to database 'xyzxy' failed Error creating ArcSDE direct connection (-9).
8590
12
09-23-2010 06:09 AM
SelcanGuner
I try to install ArcSDE (10) for SQLServer 2008. When I do post install I get an error during repository setup process which says "The ArcSDE repository unsuccessfully completed".In the txt file details are:
Connection to MyDatabase failed(0)
ESRI ArcSDE Server Setup Utility ....... Sep ............
It does not move on post install .. Do you have any idea what is the problem and the solution for it.. Thank you for spending time on my problem..
VishApte
I had exact same error and took a while to determine the cause.
I was doing the ArcSDE 10 64 bit post-install as SDE user and was specifying the SDE password that did not meet SQL Server 2008 R2 login password policy. Would be nice if SDE Post-install gives native SQL error code.
DeminHu
During postinstallation,  did you use Sysadmin user?
ChrisWright
No kidding. Why does the ArcSDE post installer let you create a password that can't be used? this installer has not changed much in 10 years and the Oracle post installer is even worse.
