connection of aracle database to arcmap
1280
07-01-2013 03:55 PM
IndiraKhanal1
hello...I have been trying to connect oracle databse in to arcmap 10.1. It got connected but while trying to add feature type ( route network file) to the map it says "Coodinate system identifier is invalid". The tables which are not associated with any geometry are displayed but the geometry related files are not showing up. I would really appreciate on any comment and thoughts.
WilliamCraft
I can't say for certain, but to me this sounds like an issue with how these tables were registered as layers.  More specifically, I am thinking that the SRID used during the layer registration is not one that ArcSDE recongnizes or interprets correctly.  How did these tables get registered with SDE... was it via SDE command line or some other method?  Try performing a describe_long on one of the tables to see what the SRID value is.  You can also see if the spatial column is set correctly and what the coordinate system attribute comes back with.  Here's an example output:
ArcSDE 9.3.1  for Oracle11g Build 3056 Fri Sep 10 09:41:17  2010
Layer   Administration Utility
Layer Description ....: <None>
Table Owner ..........: LA
Table Name ...........: BUILDING_PY
Spatial Column .......: SHAPE
Layer Id .............: 476
SRID .................: 34
Minimum Shape Id .....: 1
Offset ...............:
  falsex: -124791099.998718
  falsey:  -91255499.999136
System Units .........:       3906.249996
Z Offset..............:          0.000000
Z Units ..............:          1.000000
Measure Offset .......: <None>
Measure Units ........: <None>
XY Cluster Tolerance .:          0.008192000008
Spatial Index ........:
  parameter:    SPIDX_GRID,GRID0=2000,GRID1=6000,FULL
  exist:        Yes
  array form:   2000,6000,0
Layer Envelope .......:
  minx:   2643628.63990, miny:    483129.61769
  maxx:   3710047.75462, maxy:   1457660.51806
Entities .............: nac+
Layer Type ...........: SDE-LOB
Creation Date ........: 07/07/11 14:02:02
I/O Mode .............: NORMAL
Autolocking ..........: Enabled
Precision.............: High
User Privileges ......: SELECT, UPDATE, INSERT, DELETE
Coordinate System ....: PROJCS["NAD_1983_StatePlane_Louisiana_South_FIPS_1702_Feet",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",3280833.333333333],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-91.33333333333333],PARAMETER["Standard_Parallel_1",29.3],PARAMETER["Standard_Parallel_2",30.7],PARAMETER["Latitude_Of_Origin",28.5],UNIT["Foot_US",0.3048006096012192]]
Layer Configuration ..: DEFAULTS
WilliamCraft
In what spatial data type does your data (route network file) exist inside Oracle (i.e., SDO_GEOMETRY, SDE_LOB, ST_GEOMETRY)?
Are these tables registered with ArcSDE as spatial data (i.e., do they have a geometry column such as a SHAPE field)?
How are you making your connection to Oracle in ArcMap... is it through database connections or are you using a Query Layer?
IndiraKhanal1
It is SDO_GEOMETRY type. Yes they have geometry columns and I am using database connections to connect oracle to arcmap.
WilliamCraft
  exist:        Yes
VinceAngelo
Esri Esteemed Contributor
I'm wondering if they were registered at all.  Query Layers don't require
pre-registration, but Enterprise Geodatabase (ArcSDE) feature classes do.
- V
