Connect to Postgresql ArcSDE 10.1
4796
07-15-2012 11:45 PM
geogeekgeogeek
i cannot connect to postgresql 9.0.5 with ArcSDE 10.1 , using ArcCatalog 10.1 , On Win 7 professional 64 bit.
i followed the steps descibed here , and installed the Pg-Agent from Stack builder , when i execute "Create Enterprise Geodatabase" i set "instance" to "localhost:5432" but i got this error :
Cannot connect to database because the database client software failed to load.  Be sure the database client software is installed and configured correctly. Failed to execute (CreateEnterpriseGeodatabase).
KimPeter
To run the Create Enterprise Geodatabase tool, you must make a direct connection to the database. Connecting directly to a database requires that you have the DBMS client files on the connecting client. See Setting up a connection to PostgreSQL (http://resources.arcgis.com/en/help/main/10.1/index.html#//002p0000003q000000). If your PostgreSQL database cluster is already set up to accept remote connections, you just need to follow the first three steps on that topic to get the client files placed in the bin directory of the ArcGIS client.
KimPeter
geogeekgeogeek
i've tried PgAgent found in Stack builder for 86x but i hasn't worked, i know that i should download these files "pg_client_windows64" and "pg_client_windows86" from custom care portal, but i haven't Access to custom care portal , can any one share these installers to download them , i know that my request is little weird but i have some time issues and limitations.
aichaous
hi could you please send me these files :pg_client_windows64 and pg_client_windows86
here is my email :[email protected]
thank you so much in advance
geogeekgeogeek
thanks a lot kpeter for the Steps , it was very useful .
