Conditional Numbering points/polygons in ArcGIS 2010
4573
08-18-2015 10:06 PM
PhoukhongPhongsa
In Excel, I can do:
In cell B2 =IF(A2=A1, B1+1,1)
Data in A1:A20
A     B
1     1
1     =IF(A2=A1, B1+1,1)
How can I do in ArcGIS Attribute Table using field calculator?
I use the AutoIncreament() ... but it work according to the OBJECT_ID and that is not CONDITIONAL...
Your help is very appreciate!
Khong
OwenEarley
I am not sure about accessing previous row values in the Field Calculator but you could do this as a python script - something like this:
import arcpy
table = "C:/Temp/Data.gdb/Test"
fields = ('A', 'B')
prevA = 0
B = 0
with arcpy.da.UpdateCursor(table, fields) as cursor:
    for row in cursor:
          # increment or reset B value
          if (row[0] == prevA):
              B += 1
          else:
              B = 1
          row[1] = B
          cursor.updateRow(row)
          # set previous A value
          prevA = row[0]
PhoukhongPhongsa
I tried it but not working.
The auto increment sorted by OBJECT_ID is okay but no condition!
Pre-Logic Script Code:
rec=0
def autoIncrement():
global rec
pStart = 1 #adjust start value, if req'd
pInterval = 2 #adjust interval value, if req'd
if (rec == 0):
rec = pStart
else:
rec = rec + pInterval
return rec
Expression:
autoIncrement()
DanPatterson_Retired
If it is a cumulative sum based upon another columns just use this field calculator expression
# cumulative sum
total = 0
def cumsum(in_field):
    global total
    total+=in_field
    return total
with cumsum(field to sum in here) as in the example below.
Perform a cumulative sum on the Group field and place the result in the Cumu_Sum field
PhoukhongPhongsa
rec=0
global rec
if (rec == 0):
rec = pStart
else:
return rec
Expression:
autoIncrement()
