Combine line and point feature classes attributes
12163
22
08-17-2015 08:15 AM
MathewSuran
I have a line feature class and point feature class in a gdb that is hosted on our server.
I want to utilize these in a webapp using the REST url.
I want to ultimately be able to only display a line feature and be able to select it to display both line and point attributes.
After doing some searching, I think I need to create a relationship class in the gdb.
Can anyone lend some expertise on best way to accomplish this?
MathewSuran
I completely agree, thanks for the advise.  Can you elaborate on how to create views on the backend?  Im using MSSQL.
sapnas
this link might get you started
resources.arcgis.com/en/help/main/10.1/index.html#//006z00000039000000
MathewSuran
Thanks for that.  How would I reference this view to plug-in to my webapp?
sapnas
Add view to your mxd and publish it as rest map service
MathewSuran
Ok, will try first thing tomorrow.
williamcarr
Could you clarify on how the line and point are related?
From my understanding, you have a line and a point with a common field, then select a line and display the point attribute with the line attribute based on a similar field?
I have a few apps where I pull a single attribute from a feature I just selected. I use it to get water hydrant ID's when our service guys click on a hydrant.
hydrantRecord = evt.graphic.attributes.HydrantID;
This is how I pull the hydrant ID from a relationship query. Then I take this universal variable and plug it into my forms. It seems this would make your attribute data available for query later on.
Are you planning on using the attribute inspector, infowindow....?
MathewSuran
I have a similar field for both line and point features that specifies the location.  The similar field will only be used for location purposes.  When the line is selected, I want to display (in the form of a graph) the points elevation (Field name=Z) that relate to the same location of the line.  The line is basically the template for where the points should be taken.  Since displaying the location of the points is not important here, this is why I want to just display the line and have all of the points elevation data be referenced when it is selected.
I am looking for the best way to set this up in the gdb I am pulling the features from.  Whether it is creating a relationship class or what Sapna suggested above.
No need for the attribute inspector or infowindow, since the elevation data will be automatically populated in the line graph.
williamcarr
Ahhh.
here is the whole function that I use to pull an attribute from a feature.(Sorry I don't have time to clean it up or test it or figure out the necessary portions. .)
You could be able to extract that attribute, in this example 'hydrantRecord', and use it in your query.
If i get some more time I'll try to come up with a better tested example if I get some time today.
          map.on("click", function(evt) {
              var selectionQuery = new esri.tasks.Query();
        var tol = map.extent.getWidth()/map.width * 30;
        var x = evt.mapPoint.x;
        var y = evt.mapPoint.y;
        var queryExtent = new esri.geometry.Extent(x-tol,y-tol,x+tol,y+tol,evt.mapPoint.spatialReference);
        selectionQuery.geometry = queryExtent;
        asdf.selectFeatures(selectionQuery, FeatureLayer.SELECTION_NEW, function(features) {
               //store the current feature
                updateFeature = features[0]; console.log("adf");
                map.infoWindow.setTitle(features[0].getLayer().name); console.log("adf");
                map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint)); console.log("adf");
    var record = document.getElementById('record');
//add event listener
record.addEventListener('click', function(e3) {
  m5.on("click", lang.hitch(this, onLayerClick2));
    var relatedTable2 = new FeatureLayer("http:", {
        mode: FeatureLayer.MODE_ONDEMAND,
        outFields: ["*"],
  console.log("Ran over the related table");
      relatedTable.on("load", lang.hitch(this, function () {
      console.log("RelatedTable Load");
        var layerInfos = [
            'featureLayer': relatedTable2,
                'showAttachments': false,
                'isEditable': true,
                'fieldInfos': arrayUtils.map(relatedTable2.fields, function (field) {
                return {
                    'fieldName': field.name,
                        'isEditable': field.editable,
                        'tooltip': field.type,
                        'label': field.alias
        var attInspector = new AttributeInspector({
            layerInfos: layerInfos
        }, domConstruct.create("div"));
        attInspector.on("attribute-change", function (evt) {
            evt.feature.attributes[evt.fieldName] = evt.fieldValue;
            evt.feature.getLayer().applyEdits(null, [evt.feature], null);
        attInspector.on("delete", function (evt) {
            evt.feature.getLayer().applyEdits(null, null, [evt.feature]);
            map.infoWindow.hide();
        map.infoWindow.setContent(attInspector.domNode);
        map.infoWindow.resize(350, 400);
  console.log("Record start")
      function onLayerClick2(evt) {
            map.infoWindow.setTitle("Searching for related items...");
            map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
//-------------------this is what is pulling the attribute for querying
console.log(hydrantRecord);
//Done pulling the valve ID
var graphicAttributes = evt.graphic.attributes;
            var title = graphicAttributes[m5.displayField];
            var objectId = graphicAttributes[m5.objectIdField];
            var relatedQuery = new RelationshipQuery();
            relatedQuery.outFields = ["*"];
            relatedQuery.relationshipId = 5;
            relatedQuery.objectIds = [objectId];
console.log("relate found?");
console.log(relatedQuery.objectIds)
            m5.queryRelatedFeatures(relatedQuery, lang.hitch(this, function (relatedRecords) {
                var fset = relatedRecords[objectId];
                if (fset) {
                    map.infoWindow.setTitle(title || "No Title");
                    var relatedObjectIds = arrayUtils.map(fset.features, function (feature) {
                        return feature.attributes[relatedTable2.objectIdField];
                    var selectQuery = new Query();
                    selectQuery.objectIds = relatedObjectIds;
                    relatedTable2.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW);
console.log(feature.attributes)
                } else {
                    map.infoWindow.setTitle("No Related Items");
MathewSuran
Thanks.  Just to clarify, did you create a relationship class in your gdb?  How do you have your data set up?
williamcarr
Yes, I created a relationship in my MapService, but I don't think you will need one.
How did you initially planned to select the feature?
