Changing Mosaic Dataset spatial reference?
3039
06-28-2013 07:52 AM
DerekWicks1
Is there any way to change the spatial reference of a Mosaic Dataset after it has been created and the rasters have been loaded in?
EricRice
Esri Alum
Hi Derek,
You can right click on the MD and make a Referenced MD that uses a different coordinate system.  Alternatively, you can create a new MD in the desired coordinate system and load it using the existing MD and the 'table raster type'.
Best,
Eric
EricRice
Esri Alum
Hi Derek,
Best,
Eric
FatihDur1
@EricRice , this is a quite old post but I stumbled across the similar problem. I have been trying to apply your suggestion but somewhat it does not work. You can find more details in my GIS-SE post, arcgis desktop - Why referenced or derived mosaic datasets do not project rasters of different coord...
DerekWicks1
Thank you Eric.
