Change point to polygon with radius by attribute
3028
03-27-2012 02:13 AM
AndreasDaim
is there a way to convert all my collected pointfeatures to circle-polygonfeatures (with the same attributefields) with a specific radius as definied in an attribute value of the pointfeature?
i used arcpad 10 in the field and it was easier and faster to use points with predefinied diameter (0-50, 50-100...) instead of circle-polygons. I also didnt find out how to make circle-polygons with a fixed radius in arcpad (in arcmap its just possible by pressing the r key). But for my further work i need circle-polygons with the right radius/diameter on the map.
And its hell of work to change this manually in fact that there are about 7000 point features.
DarrenWiens2
MVP Alum
Buffer, with field as distance.
DarrenWiens2
MVP Alum
AndreasDaim
thx a lot, worked so far!
