Change a blank field to NULL
5987
04-11-2014 12:12 PM
AprilChipman1
In ArcGIS 10.2, is there a way to change a lot of blank fields to <NULL>?
The properties are set to accept NULL values, but it is only populating the new features with NULL. All of the existing features have just been left blank.
Thanks!
TimWitt
April,
select all the fields that have an empty value, right click the column and chose "Field Calculator..." and just type
null
in the box and click OK.
This will change all the empty values to <Null>
Hope this helps!
Tim
TimWitt
April,
null
Hope this helps!
Tim
