Cast shape number field to string
2071
6
06-11-2012 10:05 AM
gilKrips
Hi, i'm trying to cast a numeric field in a shapefile feature class to string.
I tried writing "CAST("fid" as char(20)) like '%50%'" and expected it to return featues that the fid value contains the request digits but it does not seem to work.
Any suggestions?
VinceAngelo
Esri Esteemed Contributor
Shapefiles aren't SQL entities -- they don't support a cast function (I don't think
file geodatabase supports casting either). For ArcSDE tables the exact syntax
would differ by RDBMS.
- V
gilKrips
Understood, i'll do it the old fashion way with cursor..
Thanks
LanceShipman
File Geodatabase does support CAST.
gilKrips
Yes i know that.. i just didn't knew how to cast shapes or if its even possible
I see now that its not so ill run on the features with a search cursor and search manually.
with sde, gdb and mdb i am good
thank you
gilKrips
DuncanHornby
MVP Notable Contributor
Michelle Mathias‌ can you resurrect the thread that "gil Krips" found as I need to see the answer as it may solve my problem.
