Cannot delete Feature Class, after having un-registered as versioned. The item does not have a definition.
1078
12-02-2019 05:51 AM
ThomasNielsen
On our ArcGIS 10.7.1, we tried to unregister a Feature Class as not longer versioned. After this was done, we are unable to open the Feature Class:
We are also not able to re-register the Feature Class as versioned, again:
Cannot register as versioned
Our database is a Microsoft SQL Server 2016 SP2.
We also tried to delete the Feature Class, which gave the below error:
Cannot delete. The item does not have a definition.
Any idea, of how we can get this Feature Class removed, so we can re-create it?
I have tried the following:
  • Diagnose Version Metadata
  • Diagnose Table Versions
None of these found any errors.
EDIT: The table still exists in the SQL server, and we can get the data using SQL queries. But we get the error from ArcMap/ESRI tools.
VinceAngelo
Esri Esteemed Contributor
