Cannot create spatial database connection
2338
07-26-2011 07:20 AM
DonnaReeve
I'm trying to connect a computer to the geodatabase on my GIS server.  Every time I try I get a message "Failed to connect to the specified server.  SDE not running on server."  I've checked and it appears that SDE is running on the server so I don't understand why I can't make the connection.
VinceAngelo
Esri Esteemed Contributor
What version of ArcGIS are you using?  What version of ArcSDE is running?
There are several different types of connections available from ArcGIS, only the "Database
Connections" tree element manages ArcSDE connections -- are you using this?
Is there a firewall running on the ArcSDE server host?  If so, has the service port been
approved for communication from the client on that port?
Can you connect to ArcSDE from the ArcSDE server host?
- V
DonnaReeve
version 9.3.1 on both
Yes I'm using the tree element.
I am checking with my IT people on the other questions.
