Can't view feature class spatially
1168
10-23-2012 02:28 AM
HaniuHokkaido
Dear all,
I encounter a very2 strange problem...
I am trying to export a FC (namely FC_FGDB) from file geodb to ArcSDE (Oracle 11g) geodb (namely FC_SDEORA). The export is successful, absolutely normal and no errors. BUT i CAN'T see any visual display. ... Although, I am able to see all the tabular data and I can do "zoom to" to an object from a record on the table (only the object that is zoomed-to is visible, the others are invisible). The same thing happens with import or load.
If I export this FC_SDEORA with another name on the same sde geodatabase, say FC_X, then I can view the spatial and tabular data normally.
To add confusion... Then I am loading FC_FGDB from another computer to the same geodatabase. The loading is successful and I can view the FC, I can see all objects displayed as well as the tabular data ! Its like a miracle...
WTH happened ? 😄
Any suggestion welcome...
BTW, I am using: ArcSDE 10.1 without sp, Oracle 11g 32 bit, ArcGIS Desktop Advanced 10.1
HaniuHokkaido
Anyone...?
Okay, let me make it simple.. I cant view spatially after load/import a feature class to SDE geodb (oracle) server from my ArcgIS Desktop on my laptop but I am able to view it after importing/loading from another Desktop on another computer...
Why ?
SusetteMartin1
I am having a similar problem.
I loaded feature classes and could view the data in ArcMap and then it stopped displaying for unknown reasons.  I can open the attribute table, select records and when I zoom to records I can see the selected records but I cannot see any neighbouring features.
I am using the following software:
ArcGIS 10.1
SQL Server 2012
