Can't Export to Excel or Copy? (Possibly Too Much Data)
5042
10-26-2016 09:11 AM
EllieHakari
Hello Everyone!
I am handling a LOT of data. We're talking about millions of points, separated into multiple dataframes. I need to get the data into Excel. The shapefile that I'm trying to extract data from has about 100,000 rows and 20 columns. I first tried using the export to Excel tool, but it errored out. I then tried copying from the attribute table and pasting into Excel. Again, it errored in Excel, and then ArcMAP crashed. I thought that maybe there was just too much data for Excel, but I looked up the extents and it shows that Excel can handle up to a million rows and thousands of columns. So I don't know what to do at this point. Any help would be greatly appreciated!
NeilAyres
Firstly, what version of Arc are you using and next what version of excel?
The old xls had a limit of 65536 rows (2 ^ 16).
xlxs or what ever its called had just over a million rows. ( 2 ^ 20).
Is there some funny headers in the data?
Best place is the table to excel tool, but you say this is erroring out. Check paths for spaces etc.
EllieHakari
I actually figured out how to fix this by not having to export to Excel. Instead, I did a One to One spatial join and took the average of each of the fields I needed. It worked! Thank you for your quick response though!
RobertScheitlin__GISP
Ellie,
   I commonly export the table from ArcMap as TXT and then once I have that file created I change the .txt extension to .csv and then open the file in Excel.
EllieHakari
