Copy the valid data out of the FGDB, then delete the original directory.
- V
[Doh! I saw "GDB" and somehow came up with "FGDB". It's rare that you can mess
up an ArcSDE raster so badly that ArcGIS won't read it. Jake's instructions below
should delete it completely, but you can also try the halfway solution of just removing
the GDB_ITEMS entry and trying to re-register it with the geodatabase. Coordination
with Tech Support on this sort of failure is generally a good idea, mostly because this
sort of error is so rare, Esri ought to know about it. BTW, the supported way to delete
a raster from a database is also to salvage what you can into a new database.]
