Can't copy/paste personal geodatabase feature dataset
2918
05-17-2013 06:13 PM
AlexanderShenkin
Hi Folks,
I have a number of feature datasets stored in a personal geodatabase that I use for Network Analyst.  I want to create a copy of one of those feature datasets so I can change it and run it in network analyst again.  However, when i right click -> copy and then paste in ArcCatalog 10.0, i get the following error: "Failed to paste xxx.  The application is not licensed to create or modify schema for this type of data.  Item not found in this collection."
Any ideas about what's going on?  Any possible workarounds?  How would you go about creating a copy of a feature dataset in a personal geodatabase?
Thanks for any ideas!
DerekLaw
Esri Esteemed Contributor
Hi Alexander,
Please review this Esri Knowledge Base technical article,
KB #16546 - Error: The application is not licensed to modify or create schema for this type of data
Perhaps you don't have the Network Analyst extension enabled in your ArcGIS for Desktop install?
Hope this helps,
