We work within an ArcGIS Server SDE environment. We create versions off of the default for multi-user editing and reconcile/post those edits back to the default.
When posting and reconciling, all edits performed in that version (for every feature class) are moved to default. Is there a way to limit the changes pushed to only those from a particular feature class without having to go through the process of creating a separate version for each feature class and pushing them separately.
If this is not possible, does anyone know why Esri has it set up this way and have any suggestions to achieve the desired result?
