Can I add fields to feature class using SQL?
3019
10-15-2019 11:10 PM
BenVan_Kesteren1
hey,
I know in the past I have risked corrupting my ESRI Enterprise Geodatabase as I have added/removed tables using SQL, this was a hard learned lesson as I didnt know there were references to these tables, in other tables (table registry etc).
When it comes to adding or dropping fields, can I do this using SQL rather than using the arcpy or geoprocessing tools? I am finding my map services are creating locks on my datasets, and the tools fail to run.
I know in the past if I use SQL this will bypass the locks and fields can be added/removed with no issues, but I am now fearful that as this is an ESRI database, could this have knock on effects that come back to bite me later.
Any thoughts with this?
Tags (1)
JakeSkinner
Esri Esteemed Contributor
I would not recommend editing the schema within SQL Server Management Studio.
JakeSkinner
Hi Ben,
I would recommend disabling schema locking.  This will allow you to make schema changes without having to stop the service:
Disable schema locking on a map service—ArcGIS Server Administration (Windows) | ArcGIS Enterprise
BenVan_Kesteren1
I will investigate this, see if it will help.
So does this mean I cannot edit the tables (adding & dropping new fields) safely using SQL?
JakeSkinner
