Calibrated route deviates from original line
1598
09-03-2014 07:26 AM
ArnoldKuilman
As shown in the picture below, my calibrated route deviates from the original route. It only happens in very few places, and I have no clue why this happens.
Anyone an idea?
GIS for Hydrographic Surveying
Tags (3)
ArnoldKuilman
The problem is solved, there were some points along the route with the same M-Value. ArcGIS completely skips those points for calibration, and deviates from the original line.
The solution was to remove the point with identical M-values and recalibrate.
So it was a curve with real dense points and no Bezier curve.
by Anonymous User
Not applicable
Are you using calibration points, and if so, are there any points missing for the mis-shapen portion?
RichardFairhurst
Is the curve in the original route densified points or a bezier curve?  I would expect the bezier curve to cause issues and not be preserved by the route tools.  I have similar problems with the Locate Features Along Routes tool when I try to overlay line features on to a route built from bezier curves originally.
ArnoldKuilman
