Calculate Field Code Block VB Help
6677
9
03-10-2013 06:02 PM
DarrochKaye
Hi folks,
I have an empty field that I want to populate with text dependent on the value of another field. In Excel this would be a breeze but I'm having trouble with the syntax and the code block structure of the Calculate Field tool. I'm using the tool in VB mode and below is what I have currently got, resulting in the very helpful 99999 Error Code.
In Expression dialogue box:
temp
In Code Block:
DIM temp as String IF OBJECTID='1' THEN temp = 'Very Destructive' ELSEIF OBJECTID='2' THEN temp = 'Destructive' ELSEIF OBJECTID='3' THEN temp = 'Damaging' ENDIF
This is resulting in errors as described above; 'Expecting end of statement'. I'm fairly certain this is a syntax issue but if it is more complicated then please advise. any assistance would be greatly appreciated.
DK
ChrisFox3
A couple things, VBScript does not allow you to explicitly declare any data types; all variables are implicitly Variant. Statements like Dim x as String should be removed or simplified to Dim x. If you want to execute only one statement when a condition is true, you can write the code on one line, otherwise each statement needs to be on a new line ie
If....Then
statement
elseif....Then
statement
else statement
end if
Dim temp If [OBJECTID] =1 Then  temp = "Very Destructive" elseif [OBJECTID] = 2 Then  temp = "Destructive" elseif [OBJECTID] =3 Then  temp = "Damaging" else temp ="Nothing" end if
AnthonyGiles
Honored Contributor
Darroch,
Field names need to be placed in brackets:
DIM temp as String
IF [OBJECTID]='1' THEN temp = 'Very Destructive'
ELSEIF [OBJECTID]='2' THEN temp = 'Destructive'
ELSEIF [OBJECTID]='3' THEN temp = 'Damaging'
ENDIF
Regards
Anthony
DarrochKaye
Darroch,
DIM temp as String
ENDIF
Regards
Anthony
Thanks for the info but I'm still getting the same error:
General error executing calculator.
ERROR 999999: Error executing function.
Expected end of statement
Failed to execute (CalculateField).
DK
AnthonyGiles
Honored Contributor
Try using double speech marks around your text, and a space between your end and if on your last line, also the last else if only needs to be an else statement, plus the objectid field is numeric so you don't need the values in speech marks.
DIM temp as String
IF [OBJECTID] = 1 THEN temp = "Very Destructive"
ELSEIF [OBJECTID] = 2 THEN temp = "Destructive"
ELSE [OBJECTID] = 3 THEN temp = "Damaging"
END IF
DarrochKaye
DIM temp as String
END IF
I had tried various double quote and single quote methods but still receiving the same error.
N.B. This doesn't have to be written in VB; if anyone knows how to write this in Python then please comment.
DK
AnthonyGiles
Honored Contributor
Darrock,
Did you also make the other changes I suggested not just the quotes?
Regards
Anthony
P.S. not sure what version of arcmap your are using but I have just found this article:
http://support.esri.com/en/knowledgebase/techarticles/detail/25207
DarrochKaye
Darrock,
Regards
Anthony
Yeah I've tried various combinations suggested. I'm using v10.1 SP1; I'll attempt something in Python.
ChrisFox3
If....Then
statement
elseif....Then
statement
else statement
end if
DarrochKaye
If....Then
statement
elseif....Then
statement
else statement
end if
Dim temp
temp = "Damaging"
end if
Excellent Chris, this works perfectly. Thanks very much.
DK
P.S. Any idea why elseif is one work but end if is two?
ChrisFox3
DK
I am not sure, but this is consistent with all VB languages.
http://msdn.microsoft.com/en-us/library/752y8abs(v=vs.80).aspx
