CAD to Geodatabase BUG - No Output
2864
02-13-2012 12:35 PM
RossSingleton
I have been converting CAD files to GDB no problem up until recently. The conversion goes through without any errors and you get the green tick in the pop up window but  then nothing appears in the contents and there is no output!
This seems to be a reoccurring problem with other users but I haven't found a solution to it on line.
Could anyone point me in the right direction or let me know how to fix this?
Ross
CatherineGadient
We were having this problem also. The only solution I was able to find was giving it an output name with TEXT ONLY (no underscores, dashes, etc.)
RebeccaWilson
I'm sorry I don't have a real solution and I just posted a similar thread on this issue. The only (temporary) solution I have found thus far is having to export the dwg to a shapefile, not to the geodatabase. Like I said this doesn't really solve my problem either and I still am having issues projecting. Hopefully a solution will arise soon.
Rebecca
RoryStierler1
Was experiencing the same problem and this worked as a solution!
Many Thanks.
BenVan_Kesteren1
I am now experiencing this problem, has anyone got a solution to this? It appears the 'working solution' posted by Rory has since been deleted???
Cheers
