CAD to FGDB ETL error
900
03-20-2013 02:01 PM
clarenceburris
The ETL works fine when I redirect to the Visualizer but when I try and write to a FGDB I get the following error:
An error occurred while attempting to open an insert cursor on the table 'BuildingInteriorSpace'. The error number from ArcObjects is: '-2147216556'. The error message from ArcObjects is: {ArcGIS product not specified.  You must first bind to an ArcGIS version prior to using any ArcGIS components.}
A fatal error has occurred. Check the logfile above for details
Any help would be great.
JeffMiller
I seem to be receiving the same error.  Did you manage to find a solution to this problem?
