CAD->Geodatabase Not Working
3378
10-07-2013 12:29 PM
MattKeene
Hello,
Pardon me if this is already been answered.  I'm using ArcMap 10.1 and I'm trying import CAD data to a geodatabase, however when I do it, it appears to successfully run the process, but when I look that at the Geodatabase it has no output, no nothing in it.  I've read that it was a bug and I'm not sure if it's been resolved or not. Any help would be greatly appreciated.
Thanks
Matt
AndrewMaracini
Same here. Anyone out there? hellooo
would be happy to ftp file etc to someone who can test.
Andy
AkosKisreti1
I am using 10.1 SP1 too, share the files and I can test it.
Akos
AndrewMaracini
Akos
private message sent.
AndrewMaracini
Problem solved. I was trying to view/import a CAD file created with AutoCAD 13. ArcGIS doesn't support that version. I saved it as AutoCAD 2000 and it worked.
DXXX
Its the same with Microstation files. ArcGIS does not support V8 files just save them as V7 then you can use them.
