CAD: Convert dwg to dxf Files??
9719
12-30-2014 12:38 PM
JamesFitzgerald
Hey,
Is there an open-source software program to convert dwg to dxf??
Thanks
James
BondHarper
I'm not sure I've seen one. LibreDWG was an open source library, but they seem to have been beset with issues and I don't think the project actually went anywhere (anyone know?). Most everyone writing programs that need to use DWG seems to use Teigha which has various membership levels depending on what you want to do with the code.
XanderBakker
Esri Esteemed Contributor
Since you like python, you might want to give this one a try... http://yorik.uncreated.net/scripts/dxfconvert.py
It is a Linux DWG to DXF converter and requires you to have wine installed and the veryDWG utility.
KarenHodge
FWIW...the geoprocessing tool ExportToCAD will create a DXF file.  And the input could be the feature classes within a DWG.
