CAD Contour Z Values
2454
07-22-2010 06:37 AM
JamieJohnston-Stewart
I have a .dwg of contour lines, but there are no elevation values associated with the lines. Is there a way to add z values to these lines? I have a DEM of the area.
Thanks for your help.
Jamie
KarenHodge
Hi Jamie.  I'm not sure if I understand your question, but here's some info:
If the DWG file includes lightweight polylines to represent the contours, ArcMap reads the elevation of the pline as the z value.  If you want that Z value as an attribute, you can copy the cad feature class to a geodatabase and then use the GP tool "Add XY" to add the x, y, z coordinates as attributes.
If the lightweight polylines don't have an elevation, but have text near the line that represents the elevation, you may be able to use a spatial join or geoprocessing tools to associate the text as an attribute of the contour line.
Hope this helps!
KathleenGould
I am having the exact same issue...
Did you get it figured out?
I know the elevation for each line and have a field of those values in the attribute table...how do I get Arc to recognise that as the 3D elevation data?
