Bad Login while connecting SDE from ArcCatalog
3866
01-25-2012 03:58 AM
SebastianKrings
I have some mysterieous problems.
I want to try a little bit with Users and Permissions on ArcSDE for SQL Server (all on one server).
I have an account on the server, which is also sysadmin on sqlserver.
I make use of a SDE Service.
There are two databases, one was intalled with SDE and the other one with DBO.
I try to connect the sde from another machine with ArcCatalog using add spatial Database Connection.
My Account on this other machine does not match the one on the server but I use a command, to start ArcCatalog with different credentials.
available parameters are:
- the username of the Windows Server (which also is added to sysadmin to sqlserver isntance)
- the name of the Windows Server
- the users password
Connection to the SDE User Database.
1)
I start ArcCatalog with "username" and "password" and want to add a spatial connection.
1a)
I use database authentication and type in either "servername\username" and "password" or "username" and password.
--> The testConnection says badLogin.
1b)
I Use windows authentication.
--> The testConnection says succeed.
2)
I start ArcCatalog with "servername\username" and "password" and want to add a spatial connection.
2a)
I use database authentication and type in "username" and "password".
2b)
I use database authentication and type in "servername\username" and "password".
2c)
When trying to connect to the DBO user Database, every combination will fail in bad login error message.
So I do not know why there are so much bad logins (on either SDE and DBO) and why the db-authentication only works when using "servername\username" and "password" to start arcCatalog, because its db authentication, should it then doesnt matter which windows login i use on my client????
How can I connect to the DBO Geodatabase?
Thanksfor help and discussion.
SebastianKrings
Someone else told me that it could be that sql authorization is not made to authorize windows accounts which still have logins in a database instance.
If that were true it had to fail to connect with windows credentials by sql authoization. Because it does not I wonder if theres a "feature" (not calling it a bug^^) within SDE (-Service) which simple transferres the credentials to windowslogin after sql authorization failed. But then its not normals that SDE istn doing it with other login-combinations, too.
