Automatically compress File Geodabases
5148
9
12-10-2020 05:51 AM
MarkVolz
Hello,
I would like to know if there is geoprocessing script or another way to crawl through a directory and automatically compress any File Geodabases within the subfolder.  This would save me the time of needing to manually search for all of the Geodatabases in directory.
Thanks!
P.S.  I did come across this script, but it appears to apply towards SQL databases and not File Geodabases.  https://community.esri.com/t5/data-management-documents/compress-geodatabase-tool/ta-p/908944
JoeBorgione
It would not be a tough script to write; psuedo code might like look like this:
import arcpy
arcpy.env.workpace = #directory of geodatabases
fgdbList = arcpy.ListWorkspaces("*", "FileGDB")
for fgdb in fgdbList:
     arcpy.CompressFileGeodatabaseData_management(fgdb)
The question I have though is what is the purpose of compressing a file geodatabase on a regular basis?
That should just about do it....
JohannesBierer
JohannesBierer
JohannesBierer
Not tested but could work?
It's from here: "https://gis.stackexchange.com/questions/129454/how-to-compact-geodatabases-in-multiple-directories-u..."
import arcpy, os
from arcpy import env
arcpy.env.workspace = r"C:\"
for path, dirs, files in os.walk(arcpy.env.workspace):
    for dir in dirs:
        if ".gdb" in dir:
            workspace = os.path.join(path, dir)
            arcpy.Compact_management(workspace)
MarkVolz
This and Joe's code worked.
Please note that there is a difference between arcpy.Compact_management(workspace), and arcpy.CompressFileGeodatabaseData_management(workspace).  The latter of which will zip up the files.
Thank You!
JoeBorgione
import arcpy
MarkVolz
Joe,
I will check out your script to compress Geodatabases. To answer your question, the purpose of compressing the File Geodabases is to reduce the storage on older Geodatabases that are infrequently used, such as those in archive folders. In theory this should be a one-time script. All that being said, I hope I am not confusing compressing a database with compacting a database. Please let me know if you disagree.
JoeBorgione
I'm pretty sure I've never compressed a fgdb.  when I read about it in help page, I got the impression that it's a one and done operation.  Compressing an Egdb is an ongoing maintenance operation and I've written and executed scripts for those.
Robert_LeClair
Esri Esteemed Contributor
Mark - I think what you're looking for is Compact (Data Management)  to reduce file size on disk.  This keeps the contents still editable whereas Compress File Geodatabase makes the contents read-only.
JoeBorgione
From the compact help page:
swap out the following in my code:
#replace:
#with
arcpy.Compact_management(fgdb)
That should do the trick for you....
