Autocad 2013
4021
10
01-03-2013 05:17 AM
LillianJohnson
It was mentioned previously that there will be a service pack for fixing the problem regarding not being able to open Autocad 2013 in Arcgis 10.1.  Have not been able to locate this service pack.
JuanLuera
Hola Lillian,
In looking into this for you, AutoCAD products that are version 2013 are not yet supported, but will be at future releases. AutoDesk products allow users to save data back to previous versions. ArcGIS Desktop 10.1 supports AutoCAD file types through version 2012.
AutoCAD Map, AutoCAD Civil 3D, AutoCAD Land Desktop create features with their ObjectARX extension. Object data are not supported in Esri software. Tools are avilable for data conversion in both ArcGIS Desktop and with the Data Interoperability Extenson.
http://www.esri.com/software/arcgis/extensions/datainteroperability
Gracias, Lillian!
Supported CAD formats in ArcGIS
http://resources.arcgis.com/en/help/main/10.1/index.html#//001000000004000000
JustinZimmerman
Have there been any updates in regards to opening CAD 2013 files in ArcGIS yet?
SteveWatchorn
Are there any anticipated dates when the software will be compatible with AutoCAD 2013?
Thank you!
KarenHodge
The upcoming release includes 2013 support.
--Karen
Thank you!
GinaBrewer
Any progress on the release of ArcGIS for Autocad 2013?? Could really use it!! 🙂
KarenHodge
AutoCAD 2013 support is in the upcoming release of ArcGIS.
VictorPierce
Do you guys have a DATE when the ArcGIS and AutoCAD compatibility ussue will be resolved? Thanks :confused:
MelanieMaguire
Hi Karen,
Is there a target/estimated date for the upcoming release in which ArcGIS will support AutoCAD 2013 formats?  I am trying to figure out if it would be worthwhile to install AutoCAD 2013 on a computer to save files to an older version.  Having an idea if the upcoming release is weeks, 2 months, or 6+ months away would be very useful for my decision making.
Thank you.  Melanie
KarenHodge
I don't have a date for you.  All I can say is that it will be in the upcoming 10.2 release of ArcGIS desktop.
Hi Karen,
Thank you.  Melanie
