Attribute transfer tool in a model?
2548
01-04-2013 08:58 AM
AdamDerringer
Can I use the attribute transfer tool in a model in Info 10.1? Basically I have multiple sets of features all with different geometries and attributes.  I would like to have multiple "Attribute Transfer Tools" active in the same map each with its own set of mapped attributes.  In this case it is required that I work will all datasets at once.
JuanLuera
Hola Adam,
In researching this for you, this is currently not an option from within model builder. Simply because currently we do not have an existing geoprocessing tool; which you would be able to use from within the model. As an option though, I was able to locate some documentation, where you could do this within arcpy. You are able to use the Cursor and Update Cursor functions, from within arcpy and I am including the help documentation for you on this. Gracias, Adam!
Cursor (arcpy)
http://resources.arcgis.com/en/help/main/10.1/index.html#//018z0000009r000000
