ArcSDE - unlocking a feature locked through WFS GetFeatureWithLock operation
794
09-14-2012 12:19 AM
MontserratMarco
How can I unlock a feature locked with the WFS GetFeatureWithLock operation and without using the WFS Transaction operation neither waiting for the timeout. I'm using ArcGis Server 10.1.
I suppose that the lock remains in a table in the ArcSDE database until timeout. I would like to know what table(s) holds the lock and the specific sentences to be executed in order to remove it.
Thanks in advance and best regards,
Montse
MontserratMarco
Answering myself: I have seen that there is a table SDE.VERSION_1_ROW_LOCKS. When I make the GetFeatureWithLock call, a record is stored in this table and disappears after timeout.
Deleting this record is enough to unlock the feature locked by GetFeatureWithLock operation or are other SDE tables involved?
Thanks in advance for your help,
Best regards,
Montse
SQL> SELECT * FROM VERSION_1_ROW_LOCKS;
LOCK_ID                                                        OC_ID     ROW_ID       ISSUE_DA     EXP_DATE
{F412B54A-DE16-4BD6-87D6-73F86A2DEB13}        641       5004          14/09/12           14/09/12
