ArcSDE table to Microsoft Access Format
1324
04-06-2011 09:49 AM
ZacharyRawe
I have a table stored in an Enterprise Geodatabase/ ArcSDE.  I need to export or import the table into microsoft access to work with.  Is there an easy way to get this table into Access format. ? Thanks.
FrankVignati
is your sde database sql server?
you should be able to just export it to an access database directly from arccatalog and/or arcmap
ZacharyRawe
Thanks.  Exporting to a personal geodatabase should do the trick.  However, when I try to do this I get the following error.  I'm not sure why it won't let me export the table.  Permissions issue.?  Any Ideas?  Thanks....
FrankVignati
you may be going about this a more difficult way than necessary
in arccatalog go to the database connection, go to the table, preview it than select the export table from the options and direct it to a personal geodatabase
