ArcSDE service not started
2437
07-27-2011 03:41 AM
ben_abdallahmhd
good morning
i have installed ArcSDE for Microsoft SQl Server Express (ArcSDE_Personal)
i would work with multiversionned view
when i test the connection to the Arcsde from MS-DOS, a message appear and confirm that sdemon is not reconized like an internal or external command or  executable programm
C:\>sdemon -o start -p sde
'sdemon' n'est pas reconnu en tant que commande interne
ou externe, un programme exécutable ou un fichier de commandes.
C:\>
i verify in the Services tab, that the ArcSDE service has not started
some idea please
thank you
i use Arcgis10 (trial version)
VinceAngelo
Esri Esteemed Contributor
Personal (and Workgroup) ArcSDE does not run as a service; only Enterprise ArcSDE does.
- V
ben_abdallahmhd
Thank you Angelo
