arcsde/sdelayer failing to log into sqlserver
1164
07-19-2010 11:00 AM
BobBoey
I'm working my way through ArcGIS Server Enterprise Configuration and Tuning for SQL Server. Sdelayer will not connect, giving me a bad login user error (-9). I'm logged in as the administrator account, with SQL Server set up to accept mixed authentication. The giomgr_esri_sde log file lists this:
Mon Jul 19 13:45:37 2010 - ****** Spatial Database I/O Manager ******
Mon Jul 19 13:45:37 2010 - SDE System Startup Initiated . . .
Mon Jul 19 13:45:37 2010 - Validated System Paths.
Mon Jul 19 13:45:37 2010 - SDE IOMGR going into background . . .
Mon Jul 19 13:45:37 2010 - System Parameter table 'SERVER_CONFIG' Read.
Mon Jul 19 13:45:37 2010 - Initialized Shared Memory Segment.
Mon Jul 19 13:45:37 2010 - Validated License.
Mon Jul 19 13:45:37 2010 - IOMGR Process ID (PID):           4200
Mon Jul 19 13:45:37 2010 - Initialized Client Tables.
Mon Jul 19 13:45:37 2010 - Server Validated.
Mon Jul 19 13:45:37 2010 - Waiting for Client Requests . . .
Mon Jul 19 13:48:18 2010 - Error (-9):Couldn't Start Server Task.
Mon Jul 19 13:48:18 2010 - Process 3840, no shared information block established
Mon Jul 19 13:48:18 2010 - SDE Server 3840 exit'd with status 3
and sde_esri_sde log lists this:
Connected to instance . . .
DBMS Connection established...
RDBMS:     "SQL Server"
Instance Name:    "esri_sde"
IDBInitialize::Initialize Failed
CAN'T OPEN INSTANCE: esri_sde.
Spatial Engine Connection Failed (-9).
Cannot Get Access to Instance esri_sde
[Mon Jul 19 13:48:18 2010] [0] [GIOMGR] Error (-9):Couldn't Start Server Task.
I understand that authentication is getting rejected, but I do not know where. I even tried forcing the dbinit file to the sde user name and password, but that did not work.
I'm running everything on one machine, which is running Windows 7.
AlanStearns
I've been having the same problem since upgrading our raster geodatabase to 9.3.1.  Every week or so, the giomgr service will stop accepting connections and I am unable to stop or restart it without first killing all the existing app server connections.  It's a Linux box, so I use "ps -ef | grep sderas" to locate all the existing app server connections (sderas is the name I assigned to the port) and then the "kill {pid}" command to terminate the connections.  The non-raster geodatabases are fine.
