ArcSDE Prerelease 10.1 on a new Oracle instance won't start, says compatability issue
6297
20
04-17-2012 01:24 PM
MattSimmons
I have a new oracle 11g instance where I installed ArcSDE 10.  I want to install 10.1 and so I had my DBA blow away the 10 table space (it's a dev instance).  I installed 10.1 and upon trying to start 10.1 using the sdemon -o start command I'm getting the following.
Could there still be something from ArcSDE 10 somewhere?  Any ideas what I should check?
ArcSDE 10.1  for Oracle11g Build 611 Wed Dec 21 12:41:15  2011
ST_Geometry Schema Owner: () Type Release: 0
Instance initialized for ((sde)) . . .
Connected to instance . . .
Previous SDE Server Release 0.0.0 is not compatible with the current Release 10.1.0.
Could not start ArcSDE -- Check Network, $SDEHOME disk, DBMS settings and dbinit.sde.
Chandan_KumarRath
I was thinking you had gotten an error about the DBMS client release.  Now that I see the error in your last post, though, it looks like you did not create a geodatabase.
Yes, you were right. I had not created an enterprise geodatabase. Now its done.
Thanks for all your co-operation.
Chandan.
