ArcSDE Prerelease 10.1 on a new Oracle instance won't start, says compatability issue
6293
20
04-17-2012 01:24 PM
MattSimmons
I have a new oracle 11g instance where I installed ArcSDE 10.  I want to install 10.1 and so I had my DBA blow away the 10 table space (it's a dev instance).  I installed 10.1 and upon trying to start 10.1 using the sdemon -o start command I'm getting the following.
Could there still be something from ArcSDE 10 somewhere?  Any ideas what I should check?
ArcSDE 10.1  for Oracle11g Build 611 Wed Dec 21 12:41:15  2011
ST_Geometry Schema Owner: () Type Release: 0
Instance initialized for ((sde)) . . .
Connected to instance . . .
Previous SDE Server Release 0.0.0 is not compatible with the current Release 10.1.0.
Could not start ArcSDE -- Check Network, $SDEHOME disk, DBMS settings and dbinit.sde.
KimPeter
I think the problem is the Oracle client you installed:
"I've installed the Oracle 11g 64-bit full client on the client machine"
Desktop is a 32-bit client and requires a 32-bit DBMS client.
http://resourcesbeta.arcgis.com/en/help/main/10.1/index.html#/Setting_up_a_connection_to_Oracle/002n...
"Some ArcGIS clients, such as ArcGIS for Desktop and ArcGIS Engine, are 32-bit applications. If you are making a database connection from one of these clients, you must use a 32-bit Oracle client to connect to the Oracle database. This is true even if you install the ArcGIS client application on a computer with a 64-bit operating system (OS) and the database and server OS are 64-bit."
MattSimmons
Just so I'm clear on the environment:
The Oracle server is 64-bit Linux,
ArcSDE 10.1 on Oracle is also the 64-bit version
On the client machine, the ArcGIS Desktop machine is 64-bit Windows 7, but I need to install the 32-bit Oracle client because Desktop is a 32-bit application?  I'll give this a go~
KimPeter
Yes, that is correct.
MattSimmons
And voila  - connection succeeds...:cool:
Next step will be enabling the gdb and starting the service...
FranciscoAcosta_Bazán
Hi, Kimberly
I'm in a similar problem
and in this post I can find the solution
in these lines mentioned :
If Desktop and Server are on the same server even so I have to install client 32 for oracle???
KimPeter
Yes; otherwise, you will not be able to connect from ArcGIS Desktop.
See this topic for information on having both the 32-bit and 64-bit Oracle client's installed:
http://resources.arcgis.com/en/help/main/10.1/index.html#/Setting_up_a_connection_to_Oracle/002n0000...
If both ArcGIS for Server and ArcGIS for Desktop are installed on the same Windows computer, set the PATH variable to read the 64-bit client before the 32-bit client.
Chandan_KumarRath
I am also getting the same error. I am using SQLServer 2008 Express Edition.
OS: Windows 7 Ultimate x64
Database: SQLServer Express Edition x64
Please provide a solution.
Chandan
KimPeter
Chandan,
What version of the SQL Server Native Client do you have installed?  You'll need at least the 2008 version to connect.
In the case of SQL Server, though, you run the Native Client installation that matches your OS - you cannot run the 32-bit SQL Server Native Client installation executable on a 64-bit machine.
http://resources.arcgis.com/en/help/main/10.1/#/Setting_up_a_connection_to_SQL_Server/002q0000003800...
Chandan_KumarRath
Chandan,
Peter,
Installed native client is 10.0 comes with "Microsoft SQL Server 2008 R2 RTM - Express with Management Tools" (SQLEXPRWT_x64_ENU.exe), downloaded from microsoft.com.
Is there any way-out available to run 32-bit SQL Server Native Client.
Log file:
ArcSDE 10.1  for SQL Server Build 679 Thu Apr  5 11:43:21  2012
DB_instance_open() against SQL Server using OLEDB driver.
KimPeter
I was thinking you had gotten an error about the DBMS client release.  Now that I see the error in your last post, though, it looks like you did not create a geodatabase.
