ArcSDE Java Client - Different geometries with different Service Pack versions
4194
20
07-13-2011 04:38 AM
NormanMann
I am new to the Spatial world, and even newer to the ArcGIS/ESRI world.
I am having an issue with reading geometries back from an Arc database (Oracle, using the LONG RAW column for geometries).
Basically, the software I have written very coarsley, goes through a layer and for each row, gets an identifier and the geometry. This seems to work fine in most cases. This is using service pack 3 of the jsde92_sdk and jpe92_sdk jars.
However a small amount (approx 10%) of the geometry come back incorrectly. In addition, the extent from the shape is similarily incorrect. I can see in the "f" tables, what the extent should be.
Upgrading to service pack 6 (anything later then service pack 3 seems to show this behaviour), the results are the opposite. ie the correct results are incorrect, and the incorrect ones are correct.
For example.
Using Service Pack 3  :
GEOMETRY 1        -5147258.777231589, -1.5492365164206002E7
GEOMETRY 2         527566.067680127, 195430.87323492393
Using Service Pack 6 :
GEOMETRY 1       385129.7801152915, 256278.68402232602
GEOMETRY 2        4.578372853940902E7, 1.2575864698354974E8
All stored as British National Grid. It seems to be that the way the LONG_RAW column is read has changed between these service packs? I am of the understanding the ArcMAP can read the data in a consistent , correct fashion.
Can someone shed some light on how I could get consistent results using 1 service pack?
Any help greatly appreciated.
VinceAngelo
Esri Esteemed Contributor
There are too many missing columns for the image to be of use (it seems as if both XY and Z
parameters have changed, but I'd need all seven FALSE* and *UNITS values in each row to
be sure).
You don't need console access, just a client with the 'sdestats' executable (with the rest
of an SDEHOME available for DLL resolution).
Once a release reaches "mature" status (as 9.2 has), no further patches or hotfixes will be
generated.
- V
