ArcSDE and Sql Server 2008- SDElayer register
742
09-06-2011 05:09 PM
SabitaTripathi
I am using the command below to register a table in Sql server 2008 with the geometry column as Arcsde layer.
sdelayer -o register -l SpatialTable,GeomCol1 -e p -t geometry -R 0 -C id,SDE -i NSESRIDBP01VM -u ArcGIS -p XXXXXXX -D XXXXXX
But it always returns the error:
- Entry for SDE instance not found in service file <-102>.
- Cannot get configuration information
I'm using ArcSDE 10.0 with SQL Server 2008 R2. Any idea why I am getting that error.
Sabita
VinceAngelo
Esri Esteemed Contributor
If there isn't an entry in the ...\etc\services file which corresponds to "NSESRIDBP01VM", then
the error means exactly what it says.
Given the the "instance" ends in VM, I suspect you crossed the "server" and "port" flags.
Thanks to the single database model, the database ("-D") parameter isn't really used in
application server connects anymore.
If you review the meanings of the "-s", "-i", and "-D" flags I expect you'll be able to find the
right parameter combination.
- V
SabitaTripathi
Thanks for the reply!
I got the layer to register successfully but now the problem is ArcMap/ArcCatalog crashes when I add the layer.
Any idea what may be causing this?
Sabita
VinceAngelo
After checking the System Requirements to be sure you're running a supported service
pack of  SQL-Server, and validating that ArcSDE is properly interpreting the columns with
'sdetable -o describe', you'll probably want to validate the topology in your geometry
columns.  From there the next step is Tech Support.
- V
