ArcSDE and DBMS on separate servers: underlying DBMS error (-51)
4372
06-15-2011 10:52 PM
RicardoSanabria
I have installed ArcSDE 10 sp1 and Oracle 10g on separate machines and it works fine, I followed the instructions at the web help: http://help.arcgis.com/en/geodatabase/10.0/install_guides/arcsde_for_oracle_installation_and_upgrade...
But I had to migrate my ArcSDE server 10 to another machine, so I thought that I didn't do anything at the DBMS machine, just at the ArcSDE machine, so I did the following.
Summary:
1) I installed ArcSDE 10 at the new server
2) I installed Oracle client at the new server
Like repository is already created I didn't execute sdesetup -o upgrade
3) I tried to execute sdesetup -o update_key -d ORACLE10g -s srxpnsig01 -l "...\xxxx.ecp" -u sde but I get underlying DBMS error (-51)
4) I created the service with sdeservice -o create -d ORACLE,SIG -p xxxxxx -n command, but when I tried to start it, the sde_esri_sde log file says:
ArcSDE 10.0  for Oracle10g Build 775 Fri Sep 17 11:45:27  2010
DB_open_instance()::db_connect (OCI8) error: 12154
init_DB DB_instance_open_as_dba: -51
DBMS error code: 12154
ORA-12154: TNS:could not resolve the connect identifier specified
Finally, I can connect to DBMS by sqlplus using conn sde/xxxxx command. It means sqlnet.ora and tnsnames are ok.
Some idea? Do I have to do something at the DBMS machine?
Regards,
Ricardo
VinceAngelo
Esri Esteemed Contributor
There's no need to update the license key (which resides in the database).
Did you follow step 13 to replace the "ORACLE_SID" variable name with "LOCAL"? [You shouldn't
run multiple application servers in the same instance, so the original service should be stopped
when you test, and eventually deleted with 'sdeservice -o delete'.]
Do you have multiple Oracle installs on the same host? If so, is the tnsnames.ora the
same in all ORACLE_HOMEs?
- V
RicardoSanabria
Yes, I set the LOCAL variable at the dbinit.sde file. At the new ArcSDE server I don't have others ORACLE_HOMEs.
I had stopped sde service but didn't delete, so I deleted it at the old ArcSDE server and created at the new ArcSDE server but I got the same error.
A little bit difference between old ArcSDE Server (32-bit) and the new one (64-bit) is that the new one is a virtual server but ArcSDE is installed in 32-bit.
Regards,
Ricardo
RicardoSanabria
The problem was  (x86) parenthesesin install path names on the Windows 64-bit operating system.  http://support.esri.com/en/knowledgebase/techarticles/detail/31875
Thank you everyone.
Ricardo
VinceAngelo
It's best to avoid Oracle 10.2.0.1 on all platforms.  It is not certified for use with any Esri
software -- Oracle 10.2.0.3 is the minimum stable version.
I'm allergic to directory paths that contain spaces and other special characters, and try to
avoid install on the C: drive as general policy.
- V
