ArcSDE 10 upgrade questions
670
08-05-2011 08:15 AM
DavidFlack
Hi Everyone,
I'm currently running ArcSDE 9.3.1 (SQL 2008) to host data for my ArcIMS 9.3.1 and ArcGIS Server 10 applications.  Since ArcMap Server is now history as of version 10 of IMS, I can't make 9.3.1 geodatabases go away for quite some time.  I'm looking for some options so that I can make use of ArcSDE 10.
If I upgrade to ArcSDE 10, but do not upgrade the geodatabases that I use to version 10, will this work?  I'm not clear if the version of the geodatabase or the actual version of the software is the issue here.
Otherwise, would I have to create a new instance of SQL Server?  Would SDE 9.3.1 and 10 run side-by-side on the same server?
I appreciate any advice other users could provide!
Dave
