ArcSDE 10 failed, unable to delete or re-install
4456
7
10-11-2011 06:13 AM
BonnieGardner
I am new to this, so please bear with me...
I'm trying to install -->
ArcSDE 10
OS - RHEL 5.7
DB - Oracle 11.2.0.2
Ran sdesetup - o install ....
As it turns out, we were missing a lib
We installed the lib
Tred to re-run sdesetup -o install and received the following msg:
ERROR: The geodatabase already exists. If you want to upgrade the geodatabase,
see the ArcSDE installation guide for instructions.
ERROR: Geodatabase install not completed.
Tried to ./sdesetup -o delete ... and received the following msg:
There are user connections open
on the schema geodatabase instance or master instance.
Deleting a Schema geodatabase is allowed only when
no users are connected. Disconnect all users and try again.
Tried to kill the connections--> ./sdemon -o kill -t  all ... and received the followig msg:
Set service name to use default 'esri_sde'
SDE not running on server, Unable to get instance configuration
Set the service name to 'esri_sde' and received the following msg:
I've checked all DB connections and rebooted my server to no avail...
How do I go about re-starting my ArcSDE installation?
Any assitance would be appreciated:)
VinceAngelo
Esri Esteemed Contributor
If it's an initial install that I hosed, I generally DROP USER SDE CASCADE and start over.
NOTE: IF YOU DO THIS ON AN INSTANCE WITH ST_GEOMETRY DATA IN ANY USER, IT WILL
IRREPARABLY HARM YOUR ORACLE INSTANCE.
- V
BonnieGardner
At this point there was no ST_GEOMETERY in use.
Thank you, dropping the sde user worked.
VinceAngelo
I'm glad it worked.  I didn't think it applied in your situation, but I needed the caveat in place,
just in case some later viewer of the thread came to my boss with "Vince said I should drop
the SDE user and now my database is corrupted." 😕
- V
SuleymanArslan1
Is there any way to recover from situation, which Vince Angelo mention it. (SDE user dropped while ST_GEOMETRY data available in a user.)
VinceAngelo
No.  That's why I wrote "IRREPARABLY HARM YOUR ORACLE INSTANCE". Deletion of tables
with ST_GEOMETRY columns requires SDE user triggers and tables, populated with the
correct information, and my understanding is that adding a new SDE user isn't possible
with existing references to the user.
The only "solution" I know of is to drop the database instance, recreate an empty instance
with the same SID, and restore from backup.  If you don't have a viable backup, you'll be
down to trying to export what you can for later re-import.
You should certainly contact Tech Support before you finish panicking.
- V
SuleymanArslan1
Thanks for your reply.
We drop everything in sde schema except two types (ST_DOMAIN_STATS, ST_GEOMETRY) which become invalid. Still we are not able to drop sde user.
I don't know what else we can do.
VinceAngelo
That's what irreparable means, impossible to rectify or repair.
There isn't anything you can do, except trash the instance and start over.  You should
contact Tech Support first, however.
- V
