ArcSDE 10.1 direct connection to SQL 2008 R2
1940
07-04-2013 03:36 PM
AngieGarcia
I created a simple database within Microsoft SQL Server 2008 one table with a Lat and Long column.  I used ArcCatalog 10.1 to enable the database to create an SDE database.  The problem is when I created a new feature class from this SDE database and loaded the data from the table I see all the data within the attribute table, but no points are displayed in the data view display in Arcmap info?  The feature class has an ObjectId and shape column.  I am not sure why the points are not displayed.  Is this a known behavior in 10.1 SDE with SQL?
Thanks
WilliamCraft
Feature classes must be created from an ArcGIS application such as ArcGIS Desktop or ArcObjects via Python for example.  It sounds like you may have created a basic table in SQL Server with lat and long fields and then tried to view its spatial contents in ArcMap once you loaded values into it.  I am not certain that your table is actually registered as a LAYER in SDE (i.e., has a registered spatial column).  However, I can't be sure because I'm not clear on what you wrote.  If you have lat and long values stored in a table, you may have success with using Add XY Event Layer in ArcMap:
http://resources.arcgis.com/en/help/main/10.1/index.html#//00s50000001z000000
Having a spatial column registered with SDE in a particular coordinate system is not the same as displaying points based on lat/long values stored in a table.
AngieGarcia
I am unclear on what you mean by spatial column registered with SDE, how can I check this?  The feature class created has a Objectid*,SHAPE*, and Latitude and Longitude column.
Thanks
MarcoBoeringa
The fact that your Feature Class has a column called "Shape" does not mean there are actually shapes in there. Unless, like William suggested, you use the Add XY Event Layer option in ArcMap to convert the tabular X,Y data to a dynamically created point layer, and export the data from there to a static layer if needed, your X,Y data will remain just that: X,Y data.
ArcMap doesn't "magically" convert X,Y data to point shapes by loading it in a pre-existing point Feature Class, unless, you use the specific option of adding dynamic X,Y data designed for this purpose first, and than convert that layer to a static point Feature Class. Again, see the Help link above, and that William also pointed out for you, for what to do.
AngieGarcia
I understand that I can use the Display XY Data to create an XY layer.  The goal of what I am trying to do is create a dynamic SDE geodatabase, so my feature class will become a dynamic layer when I publish it as a feature service.  I want to be able to consume that service on ESRIs web application.  If I add another record to SQL database server on the back end the point feature will have a dynamic connection to SDE and display on the web application. That is why I am not using the XY display and export for the data because my data will become static and not dynamic which is what I need for my web application.  What I am asking is how can I create a dynamic SDE Geodatabase feature class so when I publish it, it becomes a dynamic feature class.  If I add another record to my SQL database that point will be displayed dynamically, like using the Add Query Layer tool?
As you know one is not able to register the source information if using the Add query layer with ArcGIS Server, unless it is stored and accessed through an ArcSDE database.  This is an issue that is resolved with the next release of ArcGIS Server 10.2.
From the reply post it was mentioned to use the specific option of adding a dynamic X, Y data.  Is there a way to create a dynamic SDE, publish it as a feature service so the data becomes dynamic?
Thanks
MarcoBoeringa
I am not entirely sure what you mean with "dynamic SDE", because data served from ArcSDE is by definition "dynamic", as pulled straight from the database...
But in terms of options of having a X,Y table data with no spatial column displayed as a dynamic point feature layer in a webapplication, you may consider re-posting this question in an ArcGIS for Server or Runtime forum. I think you are more likely to get good suggestions there instead of here in the Geodatabase & ArcSDE sub-forum.
By the way, this GIS Stack Exchange thread suggests you should be able to create a dynamic service from an X,Y event layer if the web service is based on an MXD:
http://gis.stackexchange.com/questions/25753/publish-xy-event-layer-to-arcgis-server
