ArcSDE 10.1 connection file
1629
04-23-2013 08:49 AM
WilsonLee
Hi
I have a simple question about SDE 10.1 (oracle based) connection file
For Direct SDE connection, I understand that we need to install oracle client in order to make it work
How about SDE connection via �??Create ArcSDE Connection File�?� thru toolbox. In this case, do we need to install oracle client?
thanks,
W
VinceAngelo
Esri Esteemed Contributor
All Direct Connect connections require that the database client software be available.
Query Layer connections also require a database client install.
Application Server connections do not require a database client (they use the ArcSDE
connection protocol).
- V
MichaelVolz
For the direct connection, you can install the Oracle Instant Client that is available with the ArcGIS Desktop software.  This is a light-weight Oracle Client install.
WilsonLee
thanks all!
Best,
W
