Arcpy create composite images from several single band tifs
6075
11
02-05-2014 11:56 PM
JoshuaAhmed
I have a folder containing 7 tif rasters that I would like to combine into one composite tif. I have to do this for many images so I have written a python script to speed up to process. However, I'm having some trouble collecting all of the bands from the folder and creating a composite. Any help would be much appreciated.
import arcpy, sys, os
from arcpy import env
from arcpy.sa import *
arcpy.env.overwriteOutput = True #set the script to overwrite files
#the path to where the images are stored - will need to change for each set of images as the end folders are different
path_images = "J:/Proj/Annual_time_series/Landsat Images/1987/1_001_070/"
for root, dirs, files in os.walk(path_images):
    for name in files:
        beni87 = os.path.join(root,name)
        if beni87.endswith[('B10.TIF', 'B20.TIF', 'B30.TIF', 'B40.TIF', 'B50.TIF', 'B60.TIF', 'B70.TIF')] == True: #collect band 1,2 and 3 image
            tilename = name[0:-7] #remove the band number and .tif from the end of each image to be renamed
            print tilename + "being processed."
            #the list of banded images need to be put here, or the file containing the list needs to be put here
            in_rasters = path_images + name #input the bands from the file
            out_raster = path_images + tilename + "composite.tif" #insert the name of the image between the quotation marks
            #start composite bands processing
            arcpy.CompositeBands_management(in_rasters, out_raster)
JakeSkinner
Esri Esteemed Contributor
Hi Josh,
Try passing a list of the rasters to the Composite Bands tool.  Try the following:
rasterList = []
    for name in files:
        if beni87.endswith(('B10.TIF', 'B20.TIF', 'B30.TIF', 'B40.TIF', 'B50.TIF', 'B60.TIF', 'B70.TIF')):
            rasterList.append(beni87)
out_raster = path_images + "\\" + "composite.tif"
arcpy.CompositeBands_management(rasterList, out_raster)
Also, when posting code, be sure to enclose it with CODE tags using the # symbol above.
JoshuaAhmed
Hi Josh,
rasterList = []
    for name in files:
Thanks, that was perfect! Been bugging me all day.
Josh
AshleyNewby
I am doing something similar, but I have a directory with 11 folders each containing 7 .tif layers to be combined. I tried using os.walk to go through all the folders in the directory and was able to append each folder's content into a rasterList (I emptied the list between each folder). I'm having trouble getting the tool to run on all 7 .tif files in the list. I am posting what I started with before I found this post, and then the after what I tried. In the first code I was trying to get the rasterList into the in_rasters format ex.("band1.tif; band2.tif; band3.tif") in case that was causing the tool not to run. Any help would be awesome!
import arcpy, os
#arcpy.env.workspace = "C:/Test"
myDir = arcpy.GetParameterAsText(0)
bands = []
#?myDownloads = os.listdir(myDir)
try:
    #Walk through directories
    for root, dirs, files in os.walk(myDir):
        arcpy.env.workspace = root
        for f in files:
            if f.endswith(".TIF"):
                bands.append(f)
                            #print bands
            a = ','.join(bands)
            b = a.replace(",",";")
                #[f.replace(",", ";") for f in bands]
            arcpy.CompositeBands_management(b, f[:-7] + ".img")
        print bands
        bands=[]
        print b
except:
    print "Tool did not run"
    print arcpy.GetMessages()
and after:
path_images = "C:/test" #arcpy.GetParameterAsText(0)
rasterList = []
    for name in files:
        bands = os.path.join(root,name)
        #print bands
        if bands.endswith(".TIF"):
            rasterList.append(bands)
            #print tilename + " is being processed."
        print rasterList
        out_raster = path_images + "\\" + tilename + ".img"
        print out_raster
    #arcpy.CompositeBands_management(rasterList, out_raster)
    rasterList = []
print rasterList
JakeSkinner
Hi Ashley,
What is the error you are receiving when you attempt to run your code?
AshleyNewby
oops, here is the error. And when I working on the first code, it would create a .img file with only the 1st raster. I'm having trouble with the getting the input correct for the tool to run on 7 .tif's in the one directory. Thanks a bunch!
  File "C:\Python27\ArcGIS10.1\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 323, in RunScript
    debugger.run(codeObject, __main__.__dict__, start_stepping=0)
  File "C:\Python27\ArcGIS10.1\Lib\site-packages\pythonwin\pywin\debugger\__init__.py", line 60, in run
    _GetCurrentDebugger().run(cmd, globals,locals, start_stepping)
  File "C:\Python27\ArcGIS10.1\Lib\site-packages\pythonwin\pywin\debugger\debugger.py", line 655, in run
    exec cmd in globals, locals
  File "C:\Temp\landsatLayerStk.py", line 4, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\management.py", line 12073, in CompositeBands
    raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000735: Input Rasters: Value is required
Failed to execute (CompositeBands).
JakeSkinner
Hi Ashley,
I would check your TIFF files.  Do they end with '.TIF' or '.tif'?  I would try changing the following line:
to:
if f.endswith(".TIF") or f.endswith(".tif"):
AshleyNewby
I got the same error 😞 Is there something with the format of the rasterList making the parameters not valid? I noticed in the ArcGIS resource example (http://resources.arcgis.com/en/help/main/10.1/index.html#//00170000009p000000) that a semi-colon separates the .tif files, while the list in rasterList is separated by commas.
JakeSkinner
For some reason that I'm not sure of the first raster list was coming out empty. So, I made sure to only execute the composite when the length of the rasterList was greater than 0.  I was able to get the following to work:
path_images = "C:/temp/python/raster"
rasterList = []
x = 1
    for name in files:
        if bands.endswith(".TIF") or bands.endswith(".tif"):
    if len(rasterList) > 0:
        out_raster = path_images + "/" + 'raster' + str(x) + ".img"
        rasterList = []
        x += 1
Guðjón_FjeldstedÓlafsson
This one!
