arcpy.CalculateField_management ERROR:
1440
06-19-2018 01:49 PM
by Anonymous User
Not applicable
I'm trying to display the value of 1 or 2 fields based on the input of another.
arcpy.CalculateField_management(inPoints, fieldName10, "my_func(!RdType!, !Address!, !BENQUA! )", "PYTHON_9.3", "def my_func(val, fld1, fld2):\\n    if val in ('Pr'):\\n        return fld1 & " " & fld2\\n    else:\\n        return fld1")
DanPatterson_Retired
Anthony... did you try the field calculator expression to make sure it works?  And if it does, you can triple quote to get the correct formatting and indentation.
For example (untried)
# ---- tried once
val = 'a'
fld1 = 'b'
fld2 = 'c'
    if val in ('Pr'):
        return fld1 + " " + fld2
    else:
        return fld1
'b'
# ---- then recall the function from command line and triple quote
"""def my_func(val, fld1, fld2):
    if val in ('Pr'):
    else:
        return fld1
'def my_func(val, fld1, fld2):\n    if val in (\'Pr\'):\n        return fld1 + " " + fld2\n    else:\n        return fld1\n'
# ---- or
    if val in ('Pr'):
    else:
        return fld1
'\ndef my_func(val, fld1, fld2):\n    if val in (\'Pr\'):\n        return fld1 + " " + fld2\n    else:\n        return fld1\n'
curtvprice
Hard to read this thing without the script provided as a .. script but this is not a valid Python expression:
This should be
return fld1 + " " + fld2‍‍
by Anonymous User
Not applicable
import arcpy
arcpy.env.overwriteOutput = True
arcpy.env.workspace = r"G:\GIS\Anthony\GDB\Addressing_tool\Addressing_tool_MOD\Data\gdb\Addressing.gdb"
arcpy.MakeFeatureLayer_management ("Address", "Address")
arcpy.SelectLayerByAttribute_management ("Address", "NEW_SELECTION", '"NS_Address" is Null')
#Variables
inPoints = r"Address"
featureType = "Point"
fieldName1 = "N_S"
fieldName2 = "E_W"
fieldName3 = "RWDir"
fieldName4 = "STRT_NAM"
fieldName5 = "User_Defined_Digits"
fieldName6 = "RdType"
fieldName7 = "Temp"
fieldName8 = "NS_Address"
fieldName9 = "EW_Address"
fieldName10 = "Address"
fieldName11 = "Address"
expression1 = "int(((Abs([POINT_X] - 1894420.5138)) * 0.000189394)*100)"
expression2 = "int(((Abs([POINT_Y] - 322586.0736)) * 0.000189394)*100)"
expression3 = arcpy.GetParameterAsText(0)
expression4 = arcpy.GetParameterAsText(1)
expression5 = arcpy.GetParameterAsText(2)
expression6 = arcpy.GetParameterAsText(3)
expression7 = arcpy.GetParameterAsText(4)
if expression7 == '#' or not expression7:
expression7 = 'None'
expression8 = '[Temp] & [N_S] & [User_Defined_Digits] & " " & [RWDir] & " " & [STRT_NAM] & " " & [RdType]'
expression9 = '[Temp] & [E_W] & [User_Defined_Digits] & " " & [RWDir] & " " & [STRT_NAM] & " " & [RdType]'
arcpy.AddXY_management(inPoints)
arcpy.CalculateField_management(inPoints, fieldName1, expression1)
arcpy.CalculateField_management(inPoints, fieldName2, expression2)
arcpy.CalculateField_management(inPoints, fieldName3, expression3)
arcpy.CalculateField_management(inPoints, fieldName4, expression4)
arcpy.CalculateField_management(inPoints, fieldName5, expression5)
arcpy.CalculateField_management(inPoints, fieldName6, expression6)
arcpy.CalculateField_management(inPoints, fieldName7, expression7)
arcpy.CalculateField_management(inPoints, fieldName8, expression8)
arcpy.CalculateField_management(inPoints, fieldName9, expression9)
arcpy.CalculateField_management(inPoints, fieldName10, "my_func(!RWDir!, !NS_Address!, !EW_Address! )", "PYTHON_9.3", "def my_func(val, fld1, fld2):\\n \"\"\" NS_Address if the Prefix attribute is N or S\\n EW_Address if the RWDir attribute is E or W\\n \"\"\"\\n if val in ('N', 'S'):\\n return fld1\\n elif val in ('E', 'W'):\\n return fld2\\n else:\\n return None\\n")
#pulls quadrant attribute from BENQUA layer
arcpy.MakeFeatureLayer_management("G:\GIS\Anthony\GDB\Addressing_tool\Addressing_tool_MOD\Data\gdb\Addressing.gdb\Address", "Address_lyr")
arcpy.MakeFeatureLayer_management("G:\GIS\Anthony\GDB\Addressing_tool\Addressing_tool_MOD\Data\gdb\Addressing.gdb\BENQUA", "BENQUA_lyr")
rows = arcpy.SearchCursor("BENQUA")
for row in rows:
arcpy.SelectLayerByAttribute_management("BENQUA", "NEW_SELECTION", "\"OBJECTID\" = " + str(row.getValue("OBJECTID")))
arcpy.SelectLayerByLocation_management("Address", "INTERSECT", "BENQUA", "", "NEW_SELECTION")
arcpy.CalculateField_management("Address", "BENQUA", "'{0}'".format(str(row.getValue("BENQUA"))), "PYTHON_9.3", "")
#pulls city attribute from PostalArea layer
arcpy.MakeFeatureLayer_management("G:\GIS\Anthony\GDB\Addressing_tool\Addressing_tool_MOD\Data\gdb\Addressing.gdb\PostalArea", "PostalArea")
rows = arcpy.SearchCursor("PostalArea")
for row in rows:
arcpy.SelectLayerByAttribute_management("PostalArea", "NEW_SELECTION", "\"OBJECTID\" = " + str(row.getValue("OBJECTID")))
arcpy.SelectLayerByLocation_management("Address", "INTERSECT", "PostalArea", "", "NEW_SELECTION")
arcpy.CalculateField_management("Address", "PostalArea", "'{0}'".format(str(row.getValue("PostalArea"))), "PYTHON_9.3", "")
arcpy.CalculateField_management(inPoints, fieldName11, "my_func(!RdType!, !Address!, !BENQUA! )", "PYTHON_9.3", "def my_func(val, fld1, fld2):\\n if val in ('Pr'):\\n return fld1 + " " + fld2\\n else:\\n return fld1")
# ---- tried once
val = 'a'
fld1 = 'b'
fld2 = 'c'
    if val in ('Pr'):
    else:
        return fld1
'b'
    if val in ('Pr'):
    else:
        return fld1
# ---- or
    if val in ('Pr'):
    else:
        return fld1
by Anonymous User
Not applicable
Thanks for your help on this issue.
