ArcMAP mxd Report
5048
6
03-09-2016 12:00 PM
DaveTenney
all,
  I was just curious if there is a feature that would allow arcmap to export all the information of a saved mxd to could be used create a report of all the layers and their details?
   I would love to create a nice report of the following information:
1) layer name
     a) Symbology
     b) Data Type
     c) Feature Class
     d) Geometry Type
     e) Labeling
     f) Scale Range
     g) Coordinate System
I think this would be really nice to hand to a client that really doesn't know how to dig deep into the gis to see this info. It would be a great way to show them the details upfront.
thanks
Dave
JayantaPoddar
curtvprice
This could be accomplished, especially if you don't require a lot of detail, using Python scripting (arcpy.mapping).
AdrianWelsh
MVP Honored Contributor
Could you essentially create a web map of the GIS data and deliver the link to the client? That way they can see what the symbology is supposed to mean and some other items (in the legend), and they could maybe see scale ranges and the feature class names.
You could also create an application from this web map to simplify it further. But, this may not be the approach you are looking for.
DanPatterson_Retired
You might want to have a look at Rebecca Strauch, GISP​ product here Python addin for data inventory and “broken-link” repair.  it is designed for many purposes if I am not mistaken.
JayantaPoddar
AbhishekRathi1
Dear Dave,
Kindly go through below mentioned links and hopefully it will solve your purpose.
Creating a report—Help | ArcGIS for Desktop
Working with Reports in ArcMap, Part I-Getting Started | ArcGIS Blog
JoshuaBixby
MVP Esteemed Contributor
Dave Tenney​, what have you tried thus far and what worked best for you?  If someone's comment worked better than everyone else's, please mark it correct to close out this discussion.
