ArcMap is not storing relative paths?
5460
6
12-29-2015 10:29 AM
EninnaLuli
I followed this document on storing relative paths:
Relative Paths in ArcGIS
But when I move the ArcMap document (along with my data in the same folder), the layers do not show up and there is a red exclamation points on the side of the layers. When I open the properties of the map document that I just moved, the "Store relative pathnames to data sources" is already checked.
Tags (1)
DanPatterson_Retired
Your data has to be in the same folder as the mxd or in a subfolder in the folder that the mxd is in.  Can you confirm this since some people think that relative paths means in a folder beside the one that the mxd is in
c:\mypath\myproject.mxd
c:\mypath\(all the data files in here)  .... or
c:\mypath\mydata\(all the data files in here)
anything else is not relative
EninnaLuli
It's in this type of path:
C:\Users\.............\Data\Data and Maps
several things...
which file can't be found since I only see parts of a shapefile and not a complete one... or is this only a partial list.  If you are using windows explorer can you expand the width so that the files can be seen
Why are you working in the obscurata path c:\users..... or do you have restrictions to the drive?
On a side note, if you have esri grids and the like, paths with spaces are not good.  And I vaguely remember something about mxd's beginning with numbers (this is not good for grids for sure) but it is buried in my todo list.
EninnaLuli
It is only a part of my screenshot (I have a lot of shapefiles so I used only a part to show that all the files are in the same folder).
I used c:\users... initially.. No reason, I didn't think much about that.
I deleted the spaces in the file path (named it "Data_and_Maps) and I took off the "0_" in the name of the mxd file. But the layers still do not show up when I open the map docoument
VinceAngelo
Esri Esteemed Contributor
Once you change the folder name, the MXD paths are guaranteed to be wrong.  You need to re-re-register the sources.
- V
You just don't delete spaces and remove 0's.
Copy the files to a new folder.  Start arcmap, go File Open, navigate and select the mxd.  If there are files not loaded and have the !, right-click on that layer, go to Properties, and note the path to the layer... if it isn't in the folder where the project is, it can't be loaded.
