ArcGIS online Geocode Services
5381
01-20-2015 11:13 AM
DougRitter1
I just called into support and it was explained that currently AGOL does not have a method to consume custom geocoding services (address locators) without ArcGIS server.  Is there anything of a workaround so that the internal locators can be used within web maps if they only have AGOL without ArcGIS server?
Tags (1)
TimWitt2
Do you mean like an address locator you would use within ArcGIS Desktop? If so, then no. You need a server to publish a service.
DougRitter1
Yes, that is what we are looking for.  We have been using AGOL exclusively, and it has been able to do most of what we need, but if the only way to utilize an address locator is with ArcGIS server that is odd.  It seems like there would be something for it, or plans to add it?
TimWitt2
Maybe in a future realease
Lars_Kristian_EngelsbyHansen
I am facing the same issue - my experiances with AGOL is that more features are added and still will be added. Hopefully this will be in the next release 🙂
JeffWard
Honored Contributor
To get around this I have added address points and made the full address field searchable in my web app.  You could also use parcel data if it has an address field.
Jeff Ward
Summit County, Utah
