arcgis not recognizing acad map 2013 projection
673
08-30-2013 12:56 PM
MauriceAube
We are having problems bringing in data from acad map 2013, for some reason arcgis does not recognize the projection and our data ends up thousands of kilometres off in the distance. Does anyone have an answer as to why this is happening? We use map 2012 and have never had the problem, but one of our contractors uses map 2013.
Edit.  forgot to mention that he is saving his dwg's as acad 2010 format (which 2010, 2011 & 2012 all use) but arcgis still does not recognize the projection. I can open the drawing in civil 3d 2012 and the projection is correct.
